Hello
I don't have a search function and can't switch between 2 or 4 decks , using VDJ LE with a JB SYSTEMS Kontrol 3S controller. Is this normal ? The Belgium dealer of JB SYSTEMS say that there is no search function is available with VDJ LE ?
Thanks for your response
geposted Fri 12 Apr 19 @ 12:26 pm
Correct. Strange decision by Atomix made to force you to upgrade to a licenced version.
https://www.virtualdj.com/wiki/What%20is%20the%20difference%20between%20VirtualDJ%20LE%20and%20other%20VirtualDJ%20Licenses.html
geposted Fri 12 Apr 19 @ 1:03 pm
