Topic: Loop automove trigger and jog
yavuz64PRO InfinityMember since 2016
hi guys sorry for my bad english
my 1 problem is, my master deck is 1 and i touch deck 2 , VDJ chance master deck on deck 2 .. can i disable it ?
and my 2nd problem .. can i trigger loop auto move only on press like shift button ... i press automove is on , dont press automove off ?
now i press its on i press second time press is off
geposted Sat 13 Apr 19 @ 5:06 am
1 I don't understand, what controller are you using
2 use this script
setting 'loopAutoMove' 1 while_pressed
geposted Sat 13 Apr 19 @ 7:31 am
1. Master or Active deck ?
Master deck can either be auto (default) or manually controlled. When it's auto you can't change the criteria it uses to determine which deck is master. However, keep in mind that by 99% when both tracks playing the one with highest volume (fader position) is selected as master deck.
For Active deck (which is the one I assume you mean) you can change the option "autoHeadphones" to "onload"
geposted Sat 13 Apr 19 @ 3:58 pm
thanks guys i stop chance deck :D:D
but loop auto move not works :(
controller is numark mixtrack 2 and pro 2 4 deck :)
geposted Thu 18 Apr 19 @ 7:53 am
