is there away to set a key up to turn volume down on song while a key is pressed n the relesed song goes back to normal sound like how sam broadcaster does
geposted Mon 15 Apr 19 @ 10:38 pm
deck all level X% while_pressed
geposted Mon 15 Apr 19 @ 10:41 pm
wht i need to do is when i talk i need mic activate n the after words music full volume n the released all bk to norm
geposted Tue 16 Apr 19 @ 2:07 am
Sorry I thought it would work, this one definitely does
deck 1 level 50% while_pressed & deck 2 level 50% while_pressed
geposted Tue 16 Apr 19 @ 2:42 am
yes it did all need to is rember turn mic of when ty for help
geposted Tue 16 Apr 19 @ 3:21 am
Does it only go to 50%..i tried putting in other percentages and it didn't work...thanks!..:)
geposted Sat 20 Apr 19 @ 3:46 am
Any value.
geposted Sat 20 Apr 19 @ 10:14 am
Thanks for your help, I really appreciate it..do you know if there is a way to fade it to the lower voulme for the deck?...versus it just going right to it?..:)
geposted Sat 20 Apr 19 @ 12:01 pm
I found it..i just did the custom nob to to the deck volume!...xD
geposted Sat 20 Apr 19 @ 12:10 pm
Er.....why can't you just use the deck volume?
geposted Sat 20 Apr 19 @ 12:33 pm
I wanted something extremely close to the mic button...and with custom i could put it all in the same spot..:)
geposted Sat 20 Apr 19 @ 10:34 pm
