Topic: Vdj and loopback/soundflower
BwhuDControlleristMember since 2008
Hi guys
Im trying to route individual decks out to individual channels in ableton.
I can do this with channel 1/2 with loopback(as it has 1/2 and 3/4 outs) but cant work out how to get 3/4 as the source doesnt let me add anything but vdj 1/2 channels and tried ishow u audio but that only has 1/2 outs .
Anyone got any solution? Happy to buy the premium loopback if i can achieve this? Or do i need a hardware audio interface.
Hope this makes sense t.i.a
geposted Mon 15 Apr 19 @ 11:05 pm
NicotuxHome userMember since 2014
You can acheive this by using a virtual audio device and/or an audio matrix
i.e. VB-audio virtual audio cable / virtual hifi cable https://www.vb-audio.com/Cable/
and more complex configs with their voicemeeter*banana*potato tools which provides loopbacks routers and 8x8 matrix
geposted Tue 16 Apr 19 @ 11:24 am
Thanks man will give it a try
geposted Tue 16 Apr 19 @ 11:56 am
I think you'll find that "external mixer" setups require the appropriate license (or a full Pro license).
You won't get away with configuring the audio that way if you only have a controller license.
geposted Tue 16 Apr 19 @ 4:35 pm
