Mac Mojave 10.4.3
Build 4748
Numark m6 mixer
Rane 57 mixer
Gemini sound card and some other one
When I go to the timecode setting, as well as the audio section, I don’t see any option to select phase.
Phase is an option under the controllers tab, but I don’ phase is an option under the controllers tab
Created an account with face and linked it....Any thoughts?
Build 4748
Numark m6 mixer
Rane 57 mixer
geposted Wed 17 Apr 19 @ 9:10 pm
Might be some useful info here:
http://www.virtualdj.com/forums/228583/VirtualDJ_Technical_Support/Phase_don_t_work__solved_.html?page=1
geposted Wed 17 Apr 19 @ 9:21 pm
4748?
Is that a typo? You'll need 4830 Early Access minimum.
geposted Wed 17 Apr 19 @ 9:22 pm
hmmmm-ok Idon't see any option to update VD when I start the app, how does one get the early access build?
geposted Wed 17 Apr 19 @ 10:00 pm
type "updates" into the options search
geposted Wed 17 Apr 19 @ 10:07 pm
also keep in mind that you need to connect the Phase outputs to a LINE/CD Input of your mixer. The Phono inputs will not work.
geposted Thu 18 Apr 19 @ 3:19 am
