Hi is VDJ compatible with the Traktor S4 MK1.
I am a Pro licenced user of the VDJ software but I don't know how to set it up.
Your help would be greatly appreciated.
Thank You.
Thank You.
geposted Fri 19 Apr 19 @ 11:49 am
Not an officially supported controller, but not to worry I run a S4mk1 too.
Here's the mapping and def file.
http://www.virtualdj.com/addons/14443/Traktor_Kontrol_S4.html
Read the text on the page linked
I'm sorry to tell you the jogs suck in midi mode [that's N.I.'s doing, using a proprietary protocol (for only 2 units) grrrr!]
wrote :
to make it work you will need to load up the default S4 layout in the controller editor and set all buttons (including push functions) to gate, and set the turn function on all encoders to relative.
this mapper will only function properly while the S4 is in MIDI mode, you can set your S4 to start in MIDI mode in the Controller editor settings.
geposted Fri 19 Apr 19 @ 12:03 pm
pero como se descarga eso
geposted Thu 14 Jan 21 @ 8:34 pm
