Forum: Addons
Addons comments
Topic: Hotwheel 2
geposted Tue 23 Apr 19 @ 11:34 am
A short description of this skin that I made in order to have the essentials on the eyes:
This skin allows you to set up up to eight customizable buttons.
The different functions of the buttons on the top bar are:
- 1.2.3: Reset the browser list in the original order. (e. g. for a playlist)
- X: Remove played titles from the side list
- Xclu: Audio card allowed exclusively to Virtual DJ.
- Clock
- Rec and filename
On the right you have the Sampler Volume and Main Volume controls and also the Cuemix and Headphone Volume controls. There is also a button to reset your controller.
geposted Tue 23 Apr 19 @ 8:04 pm
idj4himPRO InfinityMember since 2009
ive been waiting on a skin like this nice job
geposted Thu 25 Apr 19 @ 11:21 pm
Thank you.
I'm glad you like this skin.
geposted Fri 26 Apr 19 @ 1:27 pm
hrdnxPRO InfinityMember since 2011
Liking it much. Great work.
Is it possible to have the filter button with the options like the VDJ 8 default skin????
geposted Sat 27 Apr 19 @ 10:37 am
Great idea!
I will add it soon in the next update.
In the meantime, you can use a custom button (there are 8 of them) and map this on it : filter_selectcolorfx
geposted Sat 27 Apr 19 @ 3:32 pm
Was the graphics file resized from another skin?
The skin appearance is very blurry, and graphics & text are misaligned.
geposted Sat 27 Apr 19 @ 4:48 pm
That' s strange I tested it on 3 different PCs....with different resolutions. Can you send me a screenshot?
geposted Sat 27 Apr 19 @ 6:19 pm
mg_1978PRO InfinityMember since 2008
hi, great job! can we have slider 2 about effects in effect_3slot_layout? or number of beat about effects...
geposted Sat 27 Apr 19 @ 7:42 pm
Sorry, I can't now. I deleted the skin earlier.
When I looked at the PNG file it certainly looked quite blurred, as if it had been resized (you didn't say if it had).
The first thing I noticed on the skin was the text under the mixer knobs was not central. Then I noticed things like the colours on the deck option buttons were not clear or aligned. There were a lot of little problems with the clarity and alignment of graphics.
geposted Sat 27 Apr 19 @ 8:52 pm
Actually no, I didn't resize the PNG file: I started from 0 with Skinbuilder and then I added some elements to it (these may have been resized).
For misalignments, you mean the text under eq. (High/Mid/Low) I think? I could probably fix it in a future update.
This is my first skin, I created it (VirtualDJ is really fun for this!!!!) because I couldn't find any that suited me perfectly, so I thought it might interest some others.
There may be some imperfections to improve.
Thank you for your help and welcome comments.
geposted Sun 28 Apr 19 @ 2:15 pm
Thank you for the comment. I will try to add slider 2 (it just needs a little more space to add it)
Best Regard
geposted Sun 28 Apr 19 @ 2:28 pm
I'm pretty sure that one of the terms & conditions for djdad's skinbuilder is that you cannot share (upload here) skins that are made with it.
Yes, here we go:
djdad wrote :
As per the License Agreement (you may read that in the Installer), you are not permitted to share/upload/sell skins made with Skin Builder. It is meant to be used for personal purposes.
geposted Sun 28 Apr 19 @ 2:29 pm
Yes, here we go:
Not really created with Skinbuilder. This is not possible create this skin with it.
But Skinbuilder allowed me to learn how skin works. After that, I completely re-write it.
geposted Sun 28 Apr 19 @ 4:25 pm
