Hey guys i have been using vdj 5.2 since forever,  because I love a skin that is on it.
My question is, can i use this skin in a newer version of vdj?
Thanks
Thanks
geposted Tue 23 Apr 19 @ 6:55 pm
          Be specific. What skin are you talking about?
Over the years, skin code has gradually changed - so the older the skin, the less likely it is to work in the current VDJ software.
However, old skins can be updated by modifying the XML code (replacing old commands with new ones) if using the old skin is that important to you.
geposted Tue 23 Apr 19 @ 6:58 pm
          This is the skin.. yes, I would love to use this one in case I get the newest version.
How can I adjust/adapt then in the xml?
Thanks
Thanks
geposted Tue 23 Apr 19 @ 7:09 pm
          This was the default for 5.2 by the look of it. Is this the skin because you haven't actually said?
       geposted Tue 23 Apr 19 @ 7:18 pm
