What’s up ppl..okay I own 2 pioneer sb2 units..one works completely fine..the other when I plug it in VDJ doesn’t allow me to use its Asio sound card ..the controller works fine..what will I have to do to make both units work? Or is it impossible Because it’s 2 separate units?
geposted Thu 25 Apr 19 @ 11:18 pm
Asio can only work once by design.
WDM (WASAPI) can work on multiple streams.
geposted Fri 26 Apr 19 @ 6:09 am
