Hello all,
While running karaoke mode I have the background music from the automix list.
If I double click on a track that I want to skip to, VDJ locks up.
v8.3 b4848
v8.3 b4848
geposted Sat 27 Apr 19 @ 12:58 am
Should be fixed in 4909
geposted Sat 27 Apr 19 @ 4:33 pm
It still locks up for me in b4909. In Automix, it works fine. In karaoke mode, it locks up.
geposted Sun 28 Apr 19 @ 3:13 pm
Ah yes, I see now. Will fix
geposted Sun 28 Apr 19 @ 3:39 pm
I am also still trying to track down some inconsistencies with videoAudioOnlyVisualisation set to shader while in Karaoke mode. It seems to react to what is loaded in the deck, not what is loaded in the background list. The Auto-change setting does not seem to be working. And, the shader that it is stuck on is transparent. I've seen the shader run over a music video that was playing from the playlist. I've also seen the shader run when a Karaoke track was loaded into the deck.
If you like, I will be happy to start another thread on that issue.
geposted Sun 28 Apr 19 @ 10:00 pm
I did some more testing today. The auto-change setting works in Automix. It does not work in Karaoke mode. The transparency issue may be with just one of the shaders. It did not show up with others. I will keep testing on that. The videoAudioOnlyVisualisation reacts to the loaded deck not what is playing in the background list. I would think it would react to the playlist.
geposted Mon 29 Apr 19 @ 9:01 pm
I have verified that the new EA build solved the problem with the lockup. Thank you for the fix.
geposted Thu 02 May 19 @ 9:32 pm
