Topic: Early Access Build
jbezzPRO InfinityMember since 2010
Why did my computer download an early update even though I have "no" selected for the earlyAccessUpdates option? I just downloaded Early Access b.4909 even though I wanted to stick with the latest Public Build! Any ideas?
geposted Sat 27 Apr 19 @ 7:32 pm
It may have downloaded, but it won't install unless you click the 'yes' button...
geposted Sat 27 Apr 19 @ 8:40 pm
DHoudePRO InfinityMember since 2009
Same here. Now on Early Access build 4909. But I don't have them turned on. Thought it was a public build...
geposted Sat 27 Apr 19 @ 10:44 pm
Hoping for an answer!
geposted Sun 28 Apr 19 @ 1:49 am
Because build 4848 was pulled back from release to early access, if you were on 4848 you will get an update to the next early access as well.
Once this build becomes the new public build you will be updated only to new public builds next.
geposted Sun 28 Apr 19 @ 5:07 am
Adion, I thank you for a quick response!
geposted Sun 28 Apr 19 @ 12:58 pm
