Topic: Pioneer DDJ1000 And virtual DJ
Bsidez Home userMember since 2019
Hello there, im looking to buy pioneer ddj1000 and i dont really want to use rekordbox, and since its fully supported by vdj i Just got one question.
I readed here on the forum there were problems with FX working only before faders which is a huge letdown. But i also daw some post that the atomix team is fixing it but km still not sure, So can anyone confirm? Can i use FX on ddj1000 post fader with vdj?
Thank you :)
geposted Sun 28 Apr 19 @ 12:33 pm
Bsidez,.. there is an option for FX. You can have it set to Pre fader or post fader. FX work great on VDJ. The only down side so far is the crossfader curve can not be adjusted. I am hoping they can correct it with an update.
geposted Tue 30 Apr 19 @ 4:45 pm
Great, Thank you, so now nothing holds me back and i can buy ddj1000 and subscribe to vdj
geposted Wed 01 May 19 @ 1:48 pm
