Forum: VirtualDJ Skins
Topic: Can tooltips parse vars?
Can tooltips parse vars?, I use pad labels but they aren't really clear, and the var_list is annoying, taking focus and needing esc or mouse to close.
If not would an external window do it?
geposted Mon 29 Apr 19 @ 5:31 pm
<tooltip>`get_var 'MyVar'`</tooltip> should work
geposted Tue 30 Apr 19 @ 11:42 am
I tried that as a padpage pad tooltip but I just got text.
tooltip="`get_var 'r'` R" [also tried &apos;]
I'll try in the skin, pads would have been easier.
geposted Tue 30 Apr 19 @ 11:52 am
