Hi there,
in the past by default my folders were sorted in "smart" mode. Since a couple of weeks this doesn't happen anymore.
I found some old entries referring to a setting called "SortOrderDefault" which was available for Windows only. (And I guess it was in VDJ 7)
I tried different settings within the "browserSort" but I haven't found the option to set my sorting to "smart" via this option.
It really is annoying to always have to click on the most left column header to ensure "smart"-sorting being active - especially in case you change the folder/virtual folder more frequently.
Is there a simple solution for this issue?
Thanks
Thanks
geposted Wed 01 May 19 @ 11:08 pm
options keepSortOrder
geposted Wed 01 May 19 @ 11:12 pm
keepSortOrder is active and works fine for favorite folders but sadly it does not work for virtual folders anymore.
geposted Sat 04 May 19 @ 10:58 am
