Καλησπέρα , καινούργιος υπολογιστής και ξεκίνησαν τα προβλήματα (Dell g5 - vdj 8,3 - Peoneer sx2) … με διακοπές στο ήχο . Έτρεξα το Latencymon και τα αποτελέσματα τα παρακάτω :
CONCLUSION
_________________________________________________________________________________________________________
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:04:57 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-H50H6CD
OS version: Windows 10 , 10.0, build: 17134 (x64)
Hardware: G5 5587, Dell Inc., 03PVDF
CPU: GenuineIntel Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
Logical processors: 12
Processor groups: 1
RAM: 16178 MB total
CPU SPEED
Reported CPU speed: 2208 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 5202,545899
Average measured interrupt to process latency (µs): 8,256986
Highest measured interrupt to DPC latency (µs): 3235,243376
Average measured interrupt to DPC latency (µs): 2,895472
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 288,490036
Driver with highest ISR routine execution time: ACPI.sys - Πρόγραμμα οδήγησης ACPI για NT, Microsoft Corporation
Highest reported total ISR routine time (%): 0,010166
Driver with highest ISR total time: ACPI.sys - Πρόγραμμα οδήγησης ACPI για NT, Microsoft Corporation
Total time spent in ISRs (%) 0,017171
ISR count (execution time <250 µs): 95970
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 4
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 2699,428442
Driver with highest DPC routine execution time: ACPI.sys - Πρόγραμμα οδήγησης ACPI για NT, Microsoft Corporation
Highest reported total DPC routine time (%): 0,080327
Driver with highest DPC total execution time: Wdf01000.sys - Χρόνος εκτέλεσης πλαισίου προγράμματος οδήγησης λειτουργίας πυρήνα, Microsoft Corporation
Total time spent in DPCs (%) 0,174872
DPC count (execution time <250 µs): 770031
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 2028
DPC count (execution time 1000-1999 µs): 85
DPC count (execution time 2000-3999 µs): 2
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: msmpeng.exe
Total number of hard pagefaults 225
Hard pagefault count of hardest hit process: 186
Number of processes hit: 12
PER CPU DATA
CPU 0 Interrupt cycle time (s): 20,968567
CPU 0 ISR highest execution time (µs): 288,490036
CPU 0 ISR total execution time (s): 0,608615
CPU 0 ISR count: 94829
CPU 0 DPC highest execution time (µs): 2699,428442
CPU 0 DPC total execution time (s): 6,135718
CPU 0 DPC count: 767161
CPU 1 Interrupt cycle time (s): 12,179545
CPU 1 ISR highest execution time (µs): 172,232790
CPU 1 ISR total execution time (s): 0,002978
CPU 1 ISR count: 991
CPU 1 DPC highest execution time (µs): 412,634964
CPU 1 DPC total execution time (s): 0,060490
CPU 1 DPC count: 1845
CPU 2 Interrupt cycle time (s): 5,652468
CPU 2 ISR highest execution time (µs): 22,663949
CPU 2 ISR total execution time (s): 0,000417
CPU 2 ISR count: 154
CPU 2 DPC highest execution time (µs): 163,217391
CPU 2 DPC total execution time (s): 0,016694
CPU 2 DPC count: 1447
CPU 3 Interrupt cycle time (s): 26,151739
CPU 3 ISR highest execution time (µs): 0,0
CPU 3 ISR total execution time (s): 0,0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 11,354167
CPU 3 DPC total execution time (s): 0,000047
CPU 3 DPC count: 9
CPU 4 Interrupt cycle time (s): 18,108716
CPU 4 ISR highest execution time (µs): 0,0
CPU 4 ISR total execution time (s): 0,0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 58,971920
CPU 4 DPC total execution time (s): 0,000311
CPU 4 DPC count: 28
CPU 5 Interrupt cycle time (s): 22,448094
CPU 5 ISR highest execution time (µs): 0,0
CPU 5 ISR total execution time (s): 0,0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 204,908514
CPU 5 DPC total execution time (s): 0,007067
CPU 5 DPC count: 674
CPU 6 Interrupt cycle time (s): 15,693005
CPU 6 ISR highest execution time (µs): 0,0
CPU 6 ISR total execution time (s): 0,0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 317,590580
CPU 6 DPC total execution time (s): 0,002461
CPU 6 DPC count: 211
CPU 7 Interrupt cycle time (s): 16,546333
CPU 7 ISR highest execution time (µs): 0,0
CPU 7 ISR total execution time (s): 0,0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 75,500906
CPU 7 DPC total execution time (s): 0,000342
CPU 7 DPC count: 22
CPU 8 Interrupt cycle time (s): 10,807807
CPU 8 ISR highest execution time (µs): 0,0
CPU 8 ISR total execution time (s): 0,0
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 158,805254
CPU 8 DPC total execution time (s): 0,004132
CPU 8 DPC count: 432
CPU 9 Interrupt cycle time (s): 11,011465
CPU 9 ISR highest execution time (µs): 0,0
CPU 9 ISR total execution time (s): 0,0
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 17,234601
CPU 9 DPC total execution time (s): 0,000045
CPU 9 DPC count: 6
CPU 10 Interrupt cycle time (s): 10,651831
CPU 10 ISR highest execution time (µs): 0,0
CPU 10 ISR total execution time (s): 0,0
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 194,462862
CPU 10 DPC total execution time (s): 0,005189
CPU 10 DPC count: 290
CPU 11 Interrupt cycle time (s): 10,585627
CPU 11 ISR highest execution time (µs): 0,0
CPU 11 ISR total execution time (s): 0,0
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 108,935688
CPU 11 DPC total execution time (s): 0,000291
CPU 11 DPC count: 21
καταρχήν είμαι άσχετος με τα Windows 10…..
με το παλιό laptop dell(Windows 7 ) και το ίδιο set up δεν είχα ποτέ πρόβλημα ..
παρακαλώ βοηθήστε...…….ευχαριστώ εκ των προτέρων ...
CONCLUSION
SYSTEM INFORMATION
Processor groups: 1
RAM: 16178 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
CPU 3 ISR count: 0
CPU 3 DPC count: 9
CPU 4 ISR count: 0
CPU 4 DPC count: 28
CPU 5 ISR count: 0
CPU 6 ISR count: 0
CPU 7 ISR count: 0
CPU 7 DPC count: 22
CPU 8 ISR count: 0
CPU 9 ISR count: 0
CPU 9 DPC count: 6
CPU 10 ISR count: 0
CPU 11 ISR count: 0
geposted Thu 02 May 19 @ 1:22 pm
Googlaρισε και φτιάξε στον υπολογιστή σου τα
ACPI.sys
Wdf01000.sys
msmpeng.exe
ACPI.sys
Wdf01000.sys
msmpeng.exe
geposted Thu 02 May 19 @ 2:29 pm
Ξεκίνα από τα βασικά:
1. Μπες εδώ: https://www.dell.com/support/home/gr/el/grbsdt1?app=products&~ck=mn και ακολούθησε όλα τα βήματα που αφορούν στο Auto-Detect (for drivers). Εφόσον γίνει λήψη και εγκατάσταση όλων των drivers (και πιθανότατα κάποιου Bios firmware Update), επανεκκίνησε...
2. Πίνακας Ελέγχου -> Επιλογές Παροχής Ενέργειας -> Εξισορρόπηση - > Αλλαγή Σχεδίου Ρυθμίσεων -> Ρυθμίσεις για Προχωρημένους -> Ρυθμίσεις USB -> Επιλεκτική Αναστολή Ενέργειας -> Απενεργοποιημένο.
3. Πίνακας Ελέγχου -> Ήχος -> Προεπιλεγμένη Συσκευή -> Ηχεία (και όχι controller)
4. VDj -> Audio -> Settings -> Πρέπουσες ρυθμίσεις
5. ASIO drivers (της SX2) -> Ξεκίνα από ένα latency της τάξεως των 15ms και "κατέβαινε"...
Ενημέρωσε τι έγινε μέχρι εκεί και βλέπουμε... Σε κάθε περίπτωση και εφόσον περαστούν όλοι οι drivers, απεγκατέστησε το προγραμματάκι της Dell, το οποίο ψάχνει - ενημερώνει - εγκαθιστά αυτόματα νέους divers και θα εγκατασταθεί κατά την διαδικασία #1...
geposted Thu 02 May 19 @ 4:34 pm
Καλησπέρα και πάλι και ευχαριστώ για την αναλυτική απάντηση παραπάνω ....
Αφού έκανα όλα τα παραπάνω....
Μετά από 1 ώρα περίπου ... ξανά ένα στιγμιαίο κόψιμο στον ήχο .... τι να πω δεν ξέρω τι άλλο να κάνω ...
geposted Tue 07 May 19 @ 5:25 pm
Κατ' αρχήν το "κοψίματα" μειώθηκαν, εν σχέσει με πρώτα? Κατά δεύτερον, όταν σου ξαναέκανε "κόψιμο", ποια ήταν η τιμή του latency?
geposted Tue 07 May 19 @ 5:45 pm
Ναι μειώθηκαν .... το latency το έχω στο 10+
geposted Tue 07 May 19 @ 5:53 pm
Θεωρητικά, μέχρι και τα 8ms δεν θα έπρεπε να αντιμετωπίζεις πρόβλημα...
Πρακτικά, πιστεύω ότι το μηχανάκι σου, εφόσον είναι καινούργιο, περιέχει ένα κάρο άσχετο software - scheduled tasks - settings - κ.α., τα οποία δημιουργούν "προβλήματα". Θα σου πρότεινα OS clean instalation, πέρασμα των τελευταίων drivers και δοκιμή απ' την αρχή...
Όσο για το LatencyMon, τρέξτο πάλι (εκ περιέργειας και μόνο), καθότι δεν αποτελούσε και δεν αποτελεί "εργαλείο αναφοράς"...
geposted Tue 07 May 19 @ 6:54 pm
Πριν από λίγο...…
CONCLUSION
LatencyMon has been analyzing your system for 0:14:22 (h:mm:ss) on processors 0,1,2,3,4 and 5.
SYSTEM INFORMATION
OS version: Windows 10 , 10.0, build: 17763 (x64)
Processor groups: 1
RAM: 16177 MB total
CPU SPEED
WARNING: the CPU speed that was measured is only a fraction of the CPU speed reported. Your CPUs may be throttled back due to variable speed settings and thermal issues. It is suggested that you run a utility which reports your actual CPU frequency and temperature.
Highest measured interrupt to process latency (µs): 2027,60
Average measured interrupt to process latency (µs): 6,842584
Highest measured interrupt to DPC latency (µs): 1962,60
Average measured interrupt to DPC latency (µs): 2,160916
REPORTED ISRs
Highest ISR routine execution time (µs): 563,759058
Highest reported total ISR routine time (%): 0,008646
Driver with highest ISR total time: Wdf01000.sys - Χρόνος εκτέλεσης πλαισίου προγράμματος οδήγησης λειτουργίας πυρήνα, Microsoft Corporation
Total time spent in ISRs (%) 0,013509
ISR count (execution time <250 µs): 299343
ISR count (execution time 500-999 µs): 99
REPORTED DPCs
Highest DPC routine execution time (µs): 2776,471920
Highest reported total DPC routine time (%): 0,088841
Total time spent in DPCs (%) 0,184577
DPC count (execution time <250 µs): 2815569
DPC count (execution time 500-999 µs): 3002
DPC count (execution time 1000-1999 µs): 119
DPC count (execution time 2000-3999 µs): 9
Process with highest pagefault count: none
Total number of hard pagefaults 0
Hard pagefault count of hardest hit process: 0
Number of processes hit: 0
PER CPU DATA
CPU 0 Interrupt cycle time (s): 50,597006
CPU 0 ISR highest execution time (µs): 563,759058
CPU 0 ISR total execution time (s): 1,391666
CPU 0 ISR count: 297961
CPU 0 DPC highest execution time (µs): 2776,471920
CPU 0 DPC total execution time (s): 18,991176
CPU 0 DPC count: 2815566
CPU 1 Interrupt cycle time (s): 63,522185
CPU 1 ISR highest execution time (µs): 103,054348
CPU 1 ISR total execution time (s): 0,005716
CPU 1 ISR count: 1481
CPU 1 DPC highest execution time (µs): 553,108696
CPU 1 DPC total execution time (s): 0,099759
CPU 1 DPC count: 2872
CPU 2 Interrupt cycle time (s): 19,109490
CPU 2 ISR highest execution time (µs): 0,0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 83,347826
CPU 2 DPC total execution time (s): 0,000596
CPU 2 DPC count: 124
CPU 3 Interrupt cycle time (s): 55,303430
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 0,0
CPU 3 DPC count: 0
CPU 4 Interrupt cycle time (s): 29,710082
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 143,440217
CPU 4 DPC total execution time (s): 0,001069
CPU 4 DPC count: 137
CPU 5 Interrupt cycle time (s): 33,231720
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 0,0
CPU 5 DPC count: 0
CONCLUSION
SYSTEM INFORMATION
Processor groups: 1
RAM: 16177 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
CPU 2 ISR count: 0
CPU 3 ISR count: 0
CPU 3 DPC count: 0
CPU 4 ISR count: 0
CPU 5 ISR count: 0
CPU 5 DPC count: 0
geposted Tue 07 May 19 @ 7:05 pm
