I am trying to record singing with karaoke songs. I want to record multiple tracks. I want to record the microphone and the music as separate tracks, so that I can then tweak the voice with reverb, etc. Now when I try it only records a master version that is a mix of both the music and the mic. Thanks
geposted Fri 03 May 19 @ 9:10 pm
for that you will need a daw not dj software
geposted Fri 03 May 19 @ 9:48 pm
