Somebody know how to set in VDJ to fade output Window för videos. Bright videos on a big LED-wall takes over so need to fade it.
Filters, effekt?
Now I use a Black picture as showlogo and trans filter. It Works but must be a better way?
Filters, effekt?
geposted Sat 04 May 19 @ 9:15 am
You can use the 'Colorize' video effect.
Set 'Strength' to 0% so it doesn't colorize, and set 'brightness' to however strong you like it.
geposted Sat 04 May 19 @ 9:21 am
Thank you.
Good tip Adion.
This is why I always try to follow the new topics on the forum.
Good tip Adion.
geposted Sat 04 May 19 @ 11:51 am
