The sound from each deck appears in the correct channel (3, 1, 2, 4) but, with exception of deck4, the other functions are not correctly mapped:
deck 1 knobs and level meter are in 3
deck 2 in 1
deck 3 in 2
how can I correct this?
PS. Have been messing with the controller set up sequence in the config controller deck setting but It didn't work for me
deck 2 in 1
deck 3 in 2
geposted Tue 07 May 19 @ 2:22 pm
In the mappers page select deck assignment as 1,2,3,4
geposted Tue 07 May 19 @ 2:33 pm
Hi, thank you for your quick reply! That's what I did and what I meant in the PS, it didn't work for me.
Problem is solved after changing the "mixerOrder" to 3,1,2,4 in the options and tweaks controller section.
Topic can be closed. TYVM.
geposted Wed 08 May 19 @ 2:34 pm
