I would like to be able to change the dashboard screens on my NS7iii to show the larger waveform per deck, with the browser in the middle screen like Serato does. (I don't want to use Serato just to have that) Pressing the "View" buttons on either side of Dashboard does nothing. Is there something in mapping to get it to display like I want?
geposted Wed 08 May 19 @ 3:34 am
The Dashboard (and NS7III screens) behave the same as in Serato. There is no way to change the behavior, as its hardcoded in its firmware.
So the VIEW button should behave the same as well. Should toggle between Performance and Browser views as per the manual http://www.virtualdj.com/manuals/hardware/numark/dashboard/displays.html
What happens when you use it ? No change in view ?
Have you updated your Dashboard/NS7III to the latest firmware available ?
geposted Wed 08 May 19 @ 12:13 pm
I was thinking the windows display driver was all that's needed. I just looked and saw there is a firmware update for the Dashboard. I'll try that when I get back home Friday. (I'm a full time truck driver now)
geposted Thu 09 May 19 @ 6:37 am
Hi everyone,
Sorry to intrude, I just got a NS7III and would like to know if it's possible to change the waveform to vertical (scratch) position on the DASHBOARD?
I contacted Numark about it and still no response from them. maybe they could add it to the new firmware.
THANKS.
THANKS.
geposted Fri 21 Aug 20 @ 3:33 pm
See post #2 from djdad.
geposted Fri 21 Aug 20 @ 3:42 pm
Thanks so I guess Maybe if I get to convence Numark to add it in future firmware is the only solution.
geposted Fri 21 Aug 20 @ 3:47 pm
