Topic: Video Recording Issue
JoeyKJPRO InfinityMember since 2008
Now using v8.3b4918 and trying to record several video clips over an audio track while playing,. I have three video clips in a folder and need to toggle each clip in a particular order manually and in sync, not able to do this in v8.
I'm using slideshow, but under settings panel I only have shuffle, length & fade?
In v7 you just needed to click each clip bank when needed and it was in sync with the track tempo, very simple process ....So how can I accomplish this in v8?
Thanks, Joey
geposted Fri 10 May 19 @ 7:41 pm
Why don't you put the clips in the sampler and just hit the pads when required?
geposted Fri 10 May 19 @ 8:21 pm
Thanks for that advice, what about the sync issue?
geposted Fri 10 May 19 @ 11:23 pm
open sample editor and click the sync button and save
will lock the sample in time with the video clip playing.
geposted Fri 10 May 19 @ 11:32 pm
Cool, thanks for that, so setup each clip this way and click to trigger when needed. Okay will have to try this tomorrow, will post back results then thanks again..
geposted Fri 10 May 19 @ 11:51 pm
