Topic: Shader bug ? not sure - Page: 2
Yeah it switches like every other cube. first one is big next one is small and so on and so on.
The EQ Bar seems like it follows the highs more then the bass if that makes sense??
geposted Sat 18 May 19 @ 8:27 pm
Narrowed down the problem with sound reactive shaders, They're only a problem with windows x64, x86 they're fine.
geposted Sun 19 May 19 @ 8:32 pm
Is that with 32 or 64 bit VDJ (or both)?
geposted Mon 20 May 19 @ 5:20 pm
32b is fine, 64b is the problem
geposted Mon 20 May 19 @ 5:30 pm
geposted Tue 04 Jun 19 @ 1:53 am
NicotuxHome userMember since 2014
geposted Tue 04 Jun 19 @ 7:07 am
Spectrum and wave data problem on win64 will be fixed in next update
geposted Sat 08 Jun 19 @ 4:10 pm
