in a way to get PiP i created a simple minimalist video skin
Which works ok. Then added
and this time there is no video background as with any other element but instead only the video from decks
finally got it work manually adding video using
specifying the master fails by keeping the initial playing channel in background without transition/video effect
<skin name="Just Video" version="8" width="1920" height="1080" breakline="1" breaklineV="1" image="transparent.png"/>
<group id="vid" >
<video x="70" y="51" width="364" height="204" source="deck" deck="1" visibility="deck 1 play ? deck 1 is_video ? true"/>
<video x="1920-364-70" y="51" width="364" height="204" source="deck" deck="2" visibility="deck 2 play ? deck 2 is_video ? true"/>
</group>
<skin name="Just Videos" version="8" width="1920" height="1080" breakline="1" breaklineV="1" image="transparent.png">
<video width="1920" height="1080">
<group id="vid" visible="get_decks & param_greater 0">
</group>
<video width="1920" height="1080" source="chanel" chan="master" >
<background x="0" y="0"/>
</video>
geposted Sat 11 May 19 @ 11:53 pm
          transparent.png plus <video> element in videoskin have strange effects. depending on <video> declaration and zoom crop or bars option. resizing have even more strange effects because of fixed position of the <video> element in the skin
another problem is videoskin engine which sometimes - often - don't show anything or background only or <video> only depending on
- the declaration of the alternative video source
- another existing videoskin variation with <video> element. In this case the variation is simply ignored
Using a videoskin with automix when a karaoke video file - with tag karaoke set - is in the playlist cancels the videoskin to use the selected karaoke one if any
Not an answer but a precision
<video width="1920" height="1080" source="chanel" chan="master"/ > <<---- missing "/"
<video width="1920" height="1080" source="master" />
works better but the <video> element is resizing from top left as X & Y are fixed to 0
transparent.png not needed because it is ignored and would be overwriten
what is fine with videoskins is the error dialog with line number would be fine to have that with skins
I promise one day i'll stop experimenting with strange use of VDJ
geposted Tue 14 May 19 @ 1:26 am
