You can use WASAPI instead of ASIO to fix the issue as well.
geposted Sat 22 Jun 19 @ 9:39 pm
Hope this might help anyone dealing with the HC4500 no audio issue on channel 3 & 4 on WASAPI. I looked at multiple threads for Win 7 and Win 10 and got some clues (I'm on Win 7). Solution go to VDJ - Options type 'Sample' in the Search Bar, select Sample Rate and change it from 48000 to 44100 (even though the sample rate was 'Automatic' for some reason it hadn't changed. Also follow all of the other advice elsewhere on this forum... USB 2 not 3, WASAPI not ASIO, Exclusive Audio Access - Yes etc.
geposted Mon 13 Apr 20 @ 7:51 am
