Topic: Previewing tracks
Hi dose anyone know how to preview a track while broadcasting, just in to headphones so it doesn’t go out on air. Thanks Indian Phill (Wolfman Radio)
geposted Sun 12 May 19 @ 9:40 pm
In Audio configuration, set the Master to the onboard soundcard and, if using a mixer like the one I use (Hercules RMX), select Hercules RMX ASIO as headphones outlet - I think an external soundcard might perform that function - either way, you also need to close the other fader you are not using and tap the PFL button, enabling you to listen to the other deck to determine that it's the correct song or version!
geposted Fri 17 May 19 @ 2:53 pm
