Hello,
I want to create my own skin. I have no idea where to start. I have tried to download a few creator/builder apps but can't figure them out. Is there any videos that I can watch to figure out how to use these apps. Are there videos on how to write my own xml file and create my own png images to use in the skin or is a creator app the only way?
Thanks for your help.
geposted Wed 15 May 19 @ 9:34 am
You can skin from scratch.
you won't find any vdj videos on making .png as that's just making a picture in photoshop or gimp.
I don't think you'll find video on writing skin.xml, as that's more text based teaching.
http://www.virtualdj.com/wiki/Modify%20a%20Skin.html
http://www.virtualdj.com/wiki/SkinSDK8.html
http://www.virtualdj.com/wiki/Browser%20in%20Window.html
Here's a crash course on the skin creator
https://www.virtualdj.com/forums/225078/VirtualDJ_Skins/Skin_Creator_-_Beta.html
geposted Wed 15 May 19 @ 10:01 am
IMO the best way to learn is to study existing skins, and start by doing a few small modifications to them, to see how the coding works.
Don't try to start from scratch now. It'll be overwhelming for you.
The skin creator by djdad is also useful for studying the concept of XML and PNG interaction, and for getting your own project off the ground once you've learned enough to do so.
geposted Wed 15 May 19 @ 4:53 pm
Hello....
Skin Virtual DJ 8_Sahara Airline_by DJ Mansour.
screenshot:
https://prnt.sc/nv51dj
screenshot:
geposted Wed 29 May 19 @ 10:26 pm
@user19764275
No links to external downloads allowed, if you want to share your skin, please submit it to atomix
http://www.virtualdj.com/plugins/upload.html
geposted Wed 29 May 19 @ 10:56 pm
Thanks
Uploaded
Best Regards.
Uploaded
Best Regards.
geposted Wed 29 May 19 @ 11:38 pm
Hello, I want to modify the default video skin for broadcast ...Is there a way to edit the .xml file in the directory \\DESKTOP\Users\rouss\Documents\VirtualDJ\VideoSkins\for Broadcast, so that I remove de bottom bar that is showing a spectral view of the played sound and tha t has too much opacity and hiding a part of my video (specially when undertittles).
The codes when openning .xml file with notepad is :
<skin name="for Broadcast" version="8" width="1920" height="1080" breaklineV="950" breaklineV2="970" comment="Rich skin focused on showing your mix" author="Atomix Productions" preview="preview.png">
<copyright>(c)2018 - Atomix Productions</copyright>
<font name="Arial" />
<group name="backgrounds">
<square name="canavas" color="#181818">
<pos x="0" y="0"/>
<size width="1920" height="1080"/>
</square>
<square name="topwave_topborder" color="#000000">
<pos x="0" y="18"/>
<size width="1920" height="2"/>
</square>
<square name="topwave_background" color="#080808">
<pos x="0" y="20"/>
<size width="1920" height="167"/>
</square>
<square name="topwave_bottomborder" color="#000000">
<pos x="0" y="20+167+1"/>
</square>
<square name="video_shadow" color="#0a0a0a" visibility="50%">
<pos x="376" y="167+20+20"/>
<size width="1168+3" height="656+3"/>
</square>
<square name="bottom_area" color="#1d1d1d">
<pos x="435" y="1080-215"/>
<size width="1050" height="215"/>
</square>
<square name="bottom_area_borderleft" color="#000000">
<pos x="435-1" y="1080-215"/>
<size width="1" height="215"/>
</square>
<square name="bottom_area_borderright" color="#000000">
<pos x="435+1050+1" y="1080-215"/>
</square>
</group>
<group name="class_defines">
<!-- visuals -->
<define class="panelback" radius="15" color="#101010" >
<pos x="+0" y="+0"/>
<size width="330" height="160"/>
</define>
<define class="textcolor" classdeck="left">
<text color="#0d86e3"/>
</define>
<define class="textcolor" classdeck="right">
<text color="#ff0000"/>
</define>
<define class="horslider" classdeck="left">
<visual>
<size width="272" height="45"/>
<off x="659" y="229"/>
</visual>
<slider orientation="horizontal">
<pos x="+12" y="+10"/>
<size width="272-24" height="45-10"/>
<on x="672" y="79"/>
<fader>
<size width="1" height="35"/>
<pos x="663" y="79"/>
</fader>
</slider>
</define>
<define class="horslider" classdeck="right">
<visual>
</visual>
<on x="672" y="129"/>
<fader>
<pos x="663" y="129"/>
</fader>
</slider>
</define>
<define class="horvisual" classdeck="left">
<visual>
</visual>
<visual type="linear" orientation="horizontal">
</visual>
</define>
<define class="horvisual" classdeck="right">
<visual>
</visual>
</visual>
</define>
<define class="bigpad" radius="15" classdeck="left">
<pos x="+25" y="+25"/>
<size width="110" height="110"/>
<gradient type="circular" color1="#1c9cff" color2="#003e5f"/>
</define>
<define class="bigpad" radius="15" classdeck="right">
<gradient type="circular" color1="#ff0202" color2="#3d0101"/>
</define>
<define class="beat_bar" classdeck="left">
<size width="38" height="38"/>
<off x="239" y="307"/>
<on x="289" y="307"/>
</define>
<define class="beat_bar" classdeck="right">
<on x="339" y="307"/>
</define>
<define class="horvumeter" classdeck="left">
<visual >
<size width="166" height="40"/>
<off x="10" y="381"/>
</visual>
<pos x="+8" y="+8"/>
<size width="150" height="25"/>
<on x="18" y="344"/>
</visual>
</define>
<define class="horvumeter" classdeck="right">
<visual >
</visual>
<on x="18" y="314"/>
</visual>
</define>
<define class="knob" classdeck="left">
<slider orientation="round">
<size width="88" height="88"/>
<fader anglemin="-145" anglemax="+145">
<size width="0" height="0"/>
<pos x="226" y="187"/>
</fader>
<fill>
<off x="442" y="187"/>
<on x="242" y="187"/>
</fill>
</slider>
<textzone>
<pos x="+20" y="+32"/>
<size width="48" height="26"/>
<text size="18" color="#aaaaaa" align="center"/>
</textzone>
</define>
<define class="knob" classdeck="right">
</fader>
<fill>
<on x="342" y="187"/>
</fill>
</slider>
<textzone>
</textzone>
</define>
<define class="pad_on" radius="10" classdeck="left">
<pos x="+10" y="+10"/>
<size width="58" height="58"/>
</define>
<define class="pad_on" radius="10" classdeck="right">
</define>
<define class="pad_off" radius="10">
<gradient type="circular" color1="#202020" color2="#000000"/>
</define>
<!-- panels-->
<define class="filterpanel">
<square class="panelback"></square>
<panel class="horslider" x="+29" y="+60"><!-- 272 -->
<visual></visual>
<slider action="filter" frommiddle="true"></slider>
</panel>
<textzone>
<pos x="+0" y="+20"/>
<size width="330" height="30"/>
<text size="30" align="center" weight="bold" color="#aaaaaa" text="FILTER"/>
</textzone>
<textzone>
<pos x="+0" y="+110"/>
<text size="24" align="center" color="#aaaaaa" action="filter_label 'clean'"/>
</textzone>
</define>
<define class="fxpanel" >
<visual></visual>
<slider action="effect_slider 'active'" frommiddle="get_effect_slider_default 'active' 0.5"></slider>
</panel>
<textzone>
<size width="330" height="34"/>
<text size="30" align="center" weight="bold" color="#aaaaaa" format="`get_effect_name 'active' & param_uppercase`"/>
</textzone>
<textzone>
<text size="22" align="center" color="#aaaaaa" format="`get_effect_slider_name 'active' 1` `get_effect_slider_text 'active' 1`"/>
</textzone>
</define>
<define class="looppanel">
<panel class="horvisual" x="+29" y="+60">
<visual></visual>
<visual source="loop_position"></visual>
</panel>
<textzone>
<pos x="+10" y="+20"/>
<text size="30" align="center" weight="bold" color="#aaaaaa" color="#aaaaaa" text="LOOP"/>
</textzone>
<textzone>
<pos x="+10" y="+110"/>
<text size="22" align="center" color="#aaaaaa" format="%loop beats"/>
</textzone>
</define>
<define class="covertimepanel" >
<cover>
<default x="35" y="21"/>
<clipmask x="35" y="163" width="110" height="110"/>
</cover>
<textzone class="textcolor" action="display_time 'elapsed,remain'">
<pos x="+20+121+20" y="+25+25"/>
<size width="150" height="46"/>
<text size="44" align="left" weight="bold" action="get_time"/>
</textzone>
<textzone action="display_time 'elapsed,remain'" visibility="loaded">
<pos x="+20+121+20" y="+25+20+46"/>
<size width="150" height="26"/>
<text size="22" align="left" color="#959595" action="display_time"/>
</textzone>
</define>
<define class="trackinfopanel" >
<textzone class="textcolor">
<pos x="+10" y="+24"/>
<size width="330-20" height="30"/>
<text size="30" align="center" action="get_artist_before_feat"/>
</textzone>
<textzone>
<pos x="+10" y="+57"/>
<size width="330-20" height="40"/>
<text size="40" align="center" weight="bold" color="#eeeeee" action="get_title_before_remix 'clean'"/>
</textzone>
<textzone>
<pos x="+10" y="+100"/>
<size width="330-20" height="26"/>
<text size="26" align="center" color="#aaaaaa" action="get_remix_after_title"/>
</textzone>
</define>
<define class="samplerpanel">
<square class="bigpad" visibility="sampler_volume"></square>
<sampleicon slot="active">
<pos x="+25+25" y="+25+25"/>
<size width="60" height="60"/>
<default x="+25+25" y="+25+25"/>
</sampleicon>
<textzone>
<size width="150" height="35"/>
<text size="32" align="left" weight="bold" color="#eeeeee" action="get_sample_name 'active' & param_uppercase"/>
</textzone>
<textzone >
<pos x="+20+121+20" y="+25+20+35"/>
<text size="22" align="left" weight="" color="#959595" text="SAMPLER"/>
</textzone>
</define>
<define class="vupanel">
<textzone>
<size width="330" height="20"/>
<text size="22" align="center" weight="" color="#5c5c5c" text="Level"/>
</textzone>
<square color="#5c5c5c" >
<pos x="+20" y="+10"/>
<size width="100" height="1"/>
</square>
<pos x="+330-20-100" y="+10"/>
</square>
<panel class="horvumeter" x="+82" y="+40"><!-- 166 px width -->
<visual></visual>
<visual source="get_level_left" ></visual>
</panel>
<panel class="horvumeter" x="+82" y="+40+50">
<visual></visual>
<visual source="get_level_right" ></visual>
</panel>
</define>
<define class="eqpanel">
<panel class="knob" x="+20" y="+40">
<slider action="eq_low" frommiddle="true"/>
<textzone><text text="LOW" /></textzone>
</panel>
<panel class="knob" x="+20+100" y="+40">
<slider action="eq_mid" frommiddle="true"/>
<textzone><text text="MID" /></textzone>
</panel>
<panel class="knob" x="+20+100+100" y="+40">
<slider action="eq_high" frommiddle="true"/>
<textzone><text text="HIGH" /></textzone>
</panel>
<textzone>
<text size="22" align="center" color="#5c5c5c" text="EQ"/>
</textzone>
</square>
</square>
</define>
<define class="padspanel">
<textzone orientation="vertical">
<pos x="+22" y="+0"/>
<size width="20" height="170"/>
<text size="25" align="center" weight="bold" color="#aaaaaa" action="pad_page & param_uppercase"/>
</textzone>
<panel class="4x2pads" x="+45" y="+8">
<square class="pad_on" visibility="pad_pushed 1 & fadeout 200ms"></square>
<square class="pad_off" visibility="not pad_pushed 1"></square>
<square class="pad_on" visibility="pad_pushed 2"><pos x="+10+58+10"/></square>
<square class="pad_off" visibility="not pad_pushed 2"><pos x="+10+58+10"/></square>
<square class="pad_on" visibility="pad_pushed 3"><pos x="+10+58+10+58+10"/></square>
<square class="pad_off" visibility="not pad_pushed 3"><pos x="+10+58+10+58+10"/></square>
<square class="pad_on" visibility="pad_pushed 4"><pos x="+10+58+10+58+10+58+10"/></square>
<square class="pad_off" visibility="not pad_pushed 4"><pos x="+10+58+10+58+10+58+10"/></square>
<square class="pad_on" visibility="pad_pushed 5"><pos y="+10+58+10"/></square>
<square class="pad_off" visibility="not pad_pushed 5"><pos y="+10+58+10"/></square>
<square class="pad_on" visibility="pad_pushed 6"><pos x="+10+58+10" y="+10+58+10"/></square>
<square class="pad_off" visibility="not pad_pushed 6"><pos x="+10+58+10" y="+10+58+10"/></square>
<square class="pad_on" visibility="pad_pushed 7"><pos x="+10+58+10+58+10" y="+10+58+10"/></square>
<square class="pad_off" visibility="not pad_pushed 7"><pos x="+10+58+10+58+10" y="+10+58+10"/></square>
<square class="pad_on" visibility="pad_pushed 8"><pos x="+10+58+10+58+10+58+10" y="+10+58+10"/></square>
<square class="pad_off" visibility="not pad_pushed 8"><pos x="+10+58+10+58+10+58+10" y="+10+58+10"/></square>
</panel>
</define>
<define class="cuepanel">
<square class="bigpad" visibility="true"></square>
<button action="nothing">
<default x="595" y="136"/>
<icon x="595" y="136" width="60" height="60"/>
</button>
<textzone>
<pos x="+20+121+20" y="+55"/>
<size width="160" height="30"/>
<text size="34" align="left" weight="bold" color="#eeeeee" action="cue_name 'active' & param_uppercase"/>
</textzone>
<textzone >
<pos x="+20+121+20" y="+55+25"/>
<text size="22" align="left" weight="" color="#bcbcbc" text="Cue Point"/>
</textzone>
</define>
</group>
<group name="waves" x="3" y="25">
<blockwave deck="left" color="#00A0FF" blocksize="5" zoom="4" center="middle">
<pos x="+0" y="+2" width="1915" height="80"/>
</blockwave>
<blockwave deck="right" color="#ff0018" blocksize="5" zoom="4" center="middle">
<pos x="+0" y="+80+2" width="1915" height="80"/>
</blockwave>
<square name="needle" color="#aaaaaa" canstretch="false">
<pos x="+0+1914/2" y="-7"/>
<size width="2" height="171"/>
</square>
</group>
<group name="crossfader" x="960-272+136" y="1080-107-23">
<visual>
</visual>
<slider action="get_crossfader_result 'full'" orientation="horizontal">
<pos x="+12" y="+0"/>
<size width="248" height="45"/>
<off x="672" y="79-10"/>
<on x="672" y="129-10"/>
<fader>
<pos x="412" y="300"/>
<size width="9" height="58"/>
</fader>
</slider>
</group>
<group name="leftdeck" x="0" y="0">
<deck deck="left">
<group name="beats" x="+90" y="+245">
<visual class="beat_bar" source="get_beat_num 1 4" >
</visual>
<visual class="beat_bar" source="get_beat_num 2 4" >
<pos x="+0+50" y="+0"/>
</visual>
<visual class="beat_bar" source="get_beat_num 3 4" >
<pos x="+0+50+50" y="+0"/>
</visual>
<visual class="beat_bar" source="get_beat_num 4 4" >
<pos x="+0+50+50+50" y="+0"/>
</visual>
<textzone>
<pos x="+0" y="+40"/>
<size width="+0+50+50+50+50" height="26"/>
<text size="22" color="#aaaaaa" weight="bold" align="center" format="%Pbpm bpm" />
</textzone>
</group>
<group name="jogwheel" x="+55" y="+360">
<visual>
<size width="268" height="268"/>
<off x="1047" y="290"/>
</visual>
<beattunnel depth="4000" color="#8a8a89">
<size width="268-50" height="268-50" />
</beattunnel>
<visual type="rotation" source="get rotation">
<on x="1357" y="2"/>
</visual>
<logo circle="true" visibility="80%">
<pos x="+100" y="+100"/>
<size width="68" height="68"/>
</logo>
<visual type="circle" source="get position">
<on x="1347" y="290"/>
</visual>
</group>
<group name="leftdeck_action" x="25" y="702">
<stack fadein="200ms" fadeout="500ms">
<pos x="+0" y="702"/>
<slot x="+0" y="+0" />
<slot x="+0" y="702+160+25" />
<!-- action -->
<item class="looppanel" visibility="is_using 'loop' 8000ms"></item>
<item class="samplerpanel" visibility="is_using 'sample' 1000ms"></item>
<item class="padspanel" visibility="is_using 'pads' 1000ms"></item>
<item class="cuepanel" visibility="is_using 'cue' 1000ms"></item>
<item class="fxpanel" visibility="is_using 'effect' 1000ms 8000ms"></item>
<item class="filterpanel" visibility="is_using 'filter' 1000ms"></item>
<!-- default -->
<item class="covertimepanel"></item>
<item class="trackinfopanel"></item>
</stack>
<pos x="445" y="+160+25" />
<item class="eqpanel" visibility="is_using 'equalizer' 2000ms"></item>
<!-- default -->
<item class="vupanel"></item>
</stack>
</group>
</deck>
</group>
<group name="rightdeck" x="+1540" y="0">
<deck deck="right">
</visual>
</visual>
</visual>
</visual>
<textzone>
</textzone>
</group>
<visual>
</visual>
</beattunnel>
</visual>
</logo>
<on x="1647" y="290"/>
</visual>
</group>
<group name="rightdeck_action" x="1920-330-25" y="702">
<pos x="1920-330-25" y="702"/>
<!-- action -->
<!-- default -->
</stack>
<pos x="1920-330-445" y="+160+25" />
<!-- default -->
</stack>
</group>
</deck>
</group>
<group name="Video Master" x="376" y="167+20+20">
<video source="master" canstretch="true">
<size width="1168" height="656"/>
</video>
<square name="bottom_area" color="#000000" radius="10" visibility="70%" canstretch="true">
<pos x="+25" y="+656-75"/>
<size width="1168-50" height="60"/>
</square>
<equalizer type="bar" nb="96" color="#8a8a89" deck="master" width="0.4" slow="true" bass="middle" mirror="false" canstretch="true">
<pos x="+25+25" y="+656-75+5"/>
<size width="1168-50-50" height="60-10" />
</equalizer>
</group>
</skin>
....I'm sure there is a way to set what I want to display (or not) in the video skin for broadcast.
So that you can easily figure out what part of the video skin I don't want to see anymore (because it hides the video rectangle with to much opacity), I join a file of the videoskin preview where I draw a yellow rectangle around the bar that is showing a spectral view of the sound that is playing, and that I don't want to show (rather see at first). Thank you for your help. Yves
<pos x="0" y="0"/>
</square>
<pos x="0" y="18"/>
</square>
<pos x="0" y="20"/>
</square>
</square>
</square>
</square>
</square>
</square>
</group>
<!-- visuals -->
</define>
</define>
</define>
<visual>
</visual>
<fader>
</fader>
</slider>
</define>
<visual>
</visual>
<fader>
</fader>
</slider>
</define>
<visual>
</visual>
</visual>
</define>
<visual>
</visual>
</visual>
</define>
</define>
</define>
</define>
</define>
<visual >
</visual>
</visual>
</define>
<visual >
</visual>
</visual>
</define>
</fader>
<fill>
</fill>
</slider>
<textzone>
</textzone>
</define>
</fader>
<fill>
</fill>
</slider>
<textzone>
</textzone>
</define>
</define>
</define>
</define>
<!-- panels-->
<visual></visual>
</panel>
<textzone>
</textzone>
<textzone>
</textzone>
</define>
<visual></visual>
</panel>
<textzone>
</textzone>
<textzone>
</textzone>
</define>
<visual></visual>
</panel>
<textzone>
</textzone>
<textzone>
</textzone>
</define>
<cover>
</cover>
</textzone>
</textzone>
</define>
</textzone>
<textzone>
</textzone>
<textzone>
</textzone>
</define>
</sampleicon>
<textzone>
</textzone>
<textzone >
</textzone>
</define>
<textzone>
</textzone>
</square>
</square>
<visual></visual>
</panel>
<visual></visual>
</panel>
</define>
</panel>
</panel>
</panel>
<textzone>
</textzone>
</square>
</square>
</define>
</textzone>
</panel>
</define>
</button>
<textzone>
</textzone>
<textzone >
</textzone>
</define>
</group>
</blockwave>
</blockwave>
</square>
</group>
<visual>
</visual>
<fader>
</fader>
</slider>
</group>
<deck deck="left">
</visual>
</visual>
</visual>
</visual>
<textzone>
</textzone>
</group>
<visual>
</visual>
</beattunnel>
</visual>
</logo>
</visual>
</group>
<!-- action -->
<!-- default -->
</stack>
<!-- default -->
</stack>
</group>
</deck>
</group>
<deck deck="right">
</visual>
</visual>
</visual>
</visual>
<textzone>
</textzone>
</group>
<visual>
</visual>
</beattunnel>
</visual>
</logo>
</visual>
</group>
<!-- action -->
<!-- default -->
</stack>
<!-- default -->
</stack>
</group>
</deck>
</group>
</video>
</square>
</equalizer>
</group>
</skin>
geposted Sun 02 Jun 19 @ 3:20 pm
no need to post the full skin script
comment out the <square ... /equalizer> from the end of the skin & you're done
<:!--square...
</equalizer-->
<:!--square...
</equalizer-->
geposted Sun 02 Jun 19 @ 3:45 pm
It would be nice if these elements were switchable from either the skin window itself, the main skin, or a keyboard /controller shortcut.
Having to manually edit XML is not very user friendly for most people.
geposted Sun 02 Jun 19 @ 4:09 pm
geposted Sun 02 Jun 19 @ 7:23 pm
<:!--square...
</equalizer-->
<:!--square...
</equalizer-->
geposted Sun 02 Jun 19 @ 7:35 pm
