Topic: Open source format
djmidzPRO InfinityMember since 2005
Is there any professional effects you can buy and use with vdj, since it's open source? Any good suggestions? Thanks
geposted Thu 16 May 19 @ 4:59 am
open sauce, huh? If you want effects look to vsts.
geposted Thu 16 May 19 @ 5:08 am
VDJ RonPRO InfinityMember since 2010
VDJ and most of the addons are not open source, shaders are one exception.
I regard VDJ as very important software..and well worth buying.
Mixxx is an inferior open source alternative.
Some open source software is very good such as Audacity.
geposted Thu 16 May 19 @ 6:15 am
I don't think OP wants sauce code, I think he means vdj permits vst use and is looking for vsts.
geposted Thu 16 May 19 @ 6:45 am
It's the same sort of thing..a lot of the vst's are freeware but not open source. It's about generally appreciating the ownership and usage of code. Some freeware which is not open source will be very good.
He does not seem to understand what open source means.
Atomix own the copyrights on VDJ2018 source code and their software is called proprietary as opposed to open source.
https://www.google.com/search?client=firefox-b-d&q=propriottory+software
This is a very basic point that all should understand.
geposted Thu 16 May 19 @ 7:00 am
[quote=locodogI think he means vdj permits vst use[/quote]
Open as in it doesn't restrict you to the built in effects like most of the competition. :-)
I'd vote for that interpretation.
geposted Thu 16 May 19 @ 5:16 pm
okm , what is it you want to add to the software? I had tons of extras that i had either bought or got for free vst. The issue is in virtual dj 2020 its 64 based and most of them were 32 bit. In saying that the stems and extras made it off the chart as is . I would like to add some more addons to fill buttons. Im into trying new ideas
geposted Tue 21 Dec 21 @ 9:09 pm
