Topic: Which version do I need?
I currently have Virtual DJ LE but you cant create a playlist there. I want a version that I can create a playlist from and set it hit play and continue to do my work around the house with out having to load individual songs. What version do I need to purchase or get? I also have version 8 same issue.
geposted Mon 20 May 19 @ 3:00 pm
That sounds like you want to use Auto mix
If you just want to use it at home without a controller, it's free
You can get it in the download section:
https://virtualdj.com/download/index.html
You can learn more about Auto mix here
geposted Mon 20 May 19 @ 3:13 pm
Will that play only what I have chosen in the order that I chose it? Or will that randomly play my whole library?
geposted Mon 20 May 19 @ 3:41 pm
Either, try it out then ask questions.
geposted Mon 20 May 19 @ 3:44 pm
