Hi!
I got the Early-Access-Update b4973. There is a change regarding the SmartPlay-function:
PLEASE, DON'T DO THIS PERMANENTLY!
Give it an option at least (for example: smartPlayLimit).
Since this is already customizable by the setting 'autoPitchRange'.
Sometimes it is important to make really far transitions or just sync a track to another very fast.
Even pitching from 63 bpm to 71 is over 11% difference, so even this gets more 'complicated'.
I personally use smartPlay VEEEEERY extensively, way more than I should...
But EXACTLY THIS FEATURE and the speed I can work with makes Virtual DJ so important und even unbeatable for me.
PLEEEASE don't make us press the sync button every single time... Make it customizable with an option or something.
The abilty to customize things is also a great advantage of Virtual DJ, so pleeeeeeeeease!
(And NOOO, I dont want to map a button with play_sync or similar... Maybe people want to do this on timecode, too... And remappig every single device is kind of unreasonable.)
Quote :
- Smart play limits auto matching bpm to +-10%
geposted Tue 21 May 19 @ 3:15 pm
But this is for automix only isn’ t ?
geposted Tue 21 May 19 @ 5:30 pm
smart play is not for automix
geposted Tue 21 May 19 @ 7:26 pm
Maybe a on/off tab will work in the settings old way vs new way
geposted Wed 22 May 19 @ 2:15 am
THIS is exactly what I mean!
So everyone could decide on his own which way he wants.
An overkill would be a value inside an option... Like 'smartPlayLimit = 25' or so...
But I don't want to ask for too much.
I would already be happy with a simple on/off switch for the limitation.
geposted Thu 23 May 19 @ 1:28 am
Hello, can you tell me where to download the b4976 to see if the s4mk3 traktor is already included, thanks
Moderation :
Off Topic. Please see and continue discussion here http://www.virtualdj.com/forums/227375/VirtualDJ_Technical_Support/Native_Instruments_Traktor_S4_MK3_Support.html
@all, please don't reply to this.
Moderation :
geposted Thu 23 May 19 @ 3:38 pm
