This time I was logged and I logged again for each instances
The proof VDJ can load multiple instances just crashing : https://pasteboard.co/IfOHEkY.jpg
The proof the all 3 instances are fully functionnal simultaneously ^^ https://pasteboard.co/IfOGkxW.jpg
In a way to make you sure there are really different instances, i enabled 3 different shaders one per instance and added a view of resourse monitor
This was a problem with "text" plugin config box which crashed its windows runtime. VDJ was playing and responding but windows suspended some threads sending a report
There are 3 VDJ running perfectly. hope you get some report this time.
geposted Wed 22 May 19 @ 3:52 am
