Topic: Filter Folders version 4973
bogartPRO InfinityMember since 2004
The early access version 4973 will not allow me to create a filter folder.
Click the icon the box pops up. Name the folder it closes and does not
create a folder.
geposted Wed 22 May 19 @ 1:23 pm
Just tested and it's working ok on my Mac.
Incidentally, it stored the new filter as a sub filter under the main 'filters', check there.
geposted Wed 22 May 19 @ 2:00 pm
Can't create filter folder on Windows 10 VDJ 32 or 64 bit version. Click on filter, box comes up to name the folder, I name the folder and then the name box goes away and nothing happens. I checked under the filter folder for the new filter but it does not appear.
geposted Wed 22 May 19 @ 2:18 pm
NicotuxHome userMember since 2014
Was testing and it's not working on my Pc.
geposted Wed 22 May 19 @ 2:20 pm
Checked everywhere; not there.
geposted Wed 22 May 19 @ 5:07 pm
hrdnxPRO InfinityMember since 2011
Same Problem here
geposted Wed 22 May 19 @ 9:22 pm
Thought it was just me.
geposted Fri 24 May 19 @ 1:38 pm
Will be fixed in next Early Access Build
geposted Fri 24 May 19 @ 2:30 pm
speaking of filter, on the default skin and FRUiTs skin the filter knob on deck 1 is now pitch. I was really confused when i used it at lastnights gig when the song jumped up and down various keys....even though the key lock was on
geposted Sat 25 May 19 @ 9:26 am
Click on the PITCH label to select a different color fx (like filter)
geposted Sat 25 May 19 @ 9:33 am
This software never ceases to amaze me, always finding things out years later. Thanks Phantom
geposted Sat 25 May 19 @ 9:43 am
MrDjLinton wrote :
speaking of filter, .....
The topic is not about Filter (and Color FX) but Filter folders ;)
geposted Sat 25 May 19 @ 11:31 am
The thread title needs changing...
geposted Sat 25 May 19 @ 1:52 pm
Agreed. I saw the thread title and thought "ah, someone else is having the same issue" and went with it.
geposted Sat 25 May 19 @ 2:13 pm
FYI there are only a handful of skins that have this colorfx selection built in (the default being one) - but if you change it, then the change is shown in other skins too (but cannot be changed back). Hence the FRUiT skin shows the change but cannot select or modify it. However, you can add a custom button to do it.
geposted Sat 25 May 19 @ 2:18 pm
