I've just updated to V8.3 b9148 (25/5/19). I now have green dots flickering around the top half of the UI. it doesn't affect functionality but is very distracting!
Any fixes? Would be great to know as I'm about to play live!
Cheers in advance!
Cheers in advance!
geposted Sat 25 May 19 @ 6:25 am
For the moment switch your graphics card from ATI to Intel.
geposted Sat 25 May 19 @ 6:35 am
Thank you, symptoms have gone!
For anyone interested, this is how I changed which graphics card VDJ uses: https://www.tenforums.com/tutorials/103965-set-preferred-gpu-apps-windows-10-a.html
geposted Sat 25 May 19 @ 6:54 am
You can also try the 64-bit version of VirtualDJ:
https://www.virtualdj.com/forums/225388/General_Discussion/VirtualDJ_2018_Windows_64-bit.html
geposted Sat 25 May 19 @ 7:58 am
What ATI Graphics card do you have exactly in your computer? I have a ATI RADEON 7570HD and never have a problem. Used in Core i5 3th gen laptop and also in a Core i7 3th processor without problems.
geposted Sat 25 May 19 @ 4:37 pm
Issue solved by updating to Radeon software 19.5.1, which I had to download and install manually (for some reason this hadn't updated for a few months, and there was no option to to check for updates within Radeon Settings). As an added bonus VirtualDJ UI now runs much smoother!
As an FYI my graphics card is an AMD Radeon R5 M255.
I will save updating to 64-bit version of VDJ for another day, thanks for bringing it to my attention though!
Cheers everyone for the help :) Gig went perfectly using the workaround from PhantomDeejay - I really appreciate your fast response sir!
geposted Sun 26 May 19 @ 8:44 am
