Topic: Bought used conroller on Ebay
Hi,
bought a used Hercules MK4 console at Ebay with a VDJ serial number under it but says its already registered what is kinda logical when the controller is used. Any chance to set this serial to my name because i own it now?
Regards, Mike
geposted Fri 31 May 19 @ 5:47 am
Licences are non-transferable unfortunately.
geposted Fri 31 May 19 @ 6:18 am
LE licences can be transferred, with the gear, OEM licences are a prime example
this one's tricky,though, the previous owner may well still be using the licence, they may well own anther mk4, they may have given it to someone else.
I'd say first idea would be contact the seller, then try Hercules.
geposted Fri 31 May 19 @ 6:23 am
Hercules said no chance when once registered and the past console owner don't use the key anymore...sights.
Think i have to look for alternative software for beginning. Just need it once a week for 2 hours.
Thanks all and great weekend :)
geposted Fri 31 May 19 @ 6:25 pm
