Is there any way to STOP my compatible/filter folder not refresh ? when I’m in a filter folders to see what songs are available to pick, the list will change when I have not exit the folder and I was not done looking @ songs are available to play. ( only refresh if I click to another folder change then back )
geposted Sat 01 Jun 19 @ 6:24 pm
But if you "stop" it will not be compatible anymore.. reason it changes, is because its dynamically adapting/updating to what you play, so if its refreshed with new songs, those new songs are compatible, not the old songs
geposted Sun 02 Jun 19 @ 12:59 pm
