Hello all,
Setup: (2) Denon 3900's, (1) denon x1600 mixer, & MSI dominator gt70 laptop, with most recent VDJ update.
Issue 1: While music is playing, there are random times there's an insanely loud abrupt stutter in the song. It lasts for half a second, then the music continues to play. What could cause this?
Issue 2: When a song is not playing and I press a cue button, there is delay in the song starting. When vinyl mode is off, this issue does not occur. Does anyone have any idea on how to fix this?
Thank you.
Thank you.
geposted Tue 04 Jun 19 @ 9:45 pm
Windows 10? 32-bit VDJ? ASIO? If yes to all try WASAPI drivers instead. I couldn’t get Denon ASIO drivers to work no matter what I did until I went to 64-bit on Windows 10.
I’m using different hardware, though (MC-6000).
geposted Tue 04 Jun 19 @ 11:04 pm
Thanks for the response.
I have windows 10 64-bit installed. I honestly switch between using the ASIO drivers and WASAPI as the sound outputs. There is a lot of inconsistency with this hardware and VDJ. Sometimes there is popping using the ASIO drivers and sometimes there is popping using the WASAPI. Sometimes there is super lag with either of those output options. I don't know where these inconsistency's come from.
geposted Wed 05 Jun 19 @ 2:35 am
I’ve never had latency issues but I’ve seen lots of people recommend latencymon to check systems for how suitable they are for real time audio applications like DJ’ing. I believe it is free to use and will look at your system for latency issues.
geposted Wed 05 Jun 19 @ 3:49 am
I can check it out but let me tell you, these issues happen no matter what computer I use or what operating system I use. There is a major issue with VDJ when external soundcards are hooked up. There is no other reasoning for this.
These issues don't occur when I use my system as standalone with CDs. These issues don't occur when I use VDJ by itself with the keyboard. The issues are 100% a VDJ problem when an external soundcard is being run through it.
geposted Wed 05 Jun 19 @ 4:22 pm
It's not that general. It's specifically Denon kit. My Pioneer controllers have no issues.
geposted Wed 05 Jun 19 @ 5:01 pm
I'm talking about the VDJ setup with Denon, I don't care about pioneer. There are persistent issues that not a single VDJ mod/rep/technician can fix. VDJ tells me it's Denon's issue and Denon tells me it's a VDJ issue.
No one knows, it should be embarrassing for everyone. I have lists upon lists of issues with VDJ, I don't understand why they don't allow me to beta test and report issues. I can find issues with VDJ any time of any day, on any computer, with every setup I've ever used. that's how bad it's gotten.
geposted Thu 06 Jun 19 @ 5:22 pm
Did you run latencymon? What were the results? Do you have access to another controller to see if it truly is the controller? You mention it's any computer and operating system.
geposted Thu 06 Jun 19 @ 5:33 pm
DJ Bertie wrote :
I'm talking about the VDJ setup with Denon/quote]
....then you shouldn't have said:
[quote]There is a major issue with VDJ when external soundcards are hooked up
....which implies that there's an issue with any external soundcard.
geposted Thu 06 Jun 19 @ 5:47 pm
this sounds silly... have you replaced your usb cable lately? I recommend a usb cable with the blocks on each end to zero out em interference.
geposted Fri 07 Jun 19 @ 4:27 pm
Same issue here, I've been reporting it for a year and no resolution. Have a numark ASIO external soundcard and always need to start VDJ, then close out, then reopen to not have the irritation of the song skipping for a half a second. This will occur only once per night.... it will go away, then it surfaces again. Gave up, but then see other people posting the exact same issue. Makes no sense
geposted Thu 20 Jun 19 @ 5:37 am
Yep, and tonight it skipped on me 3 times with the clicking, pause, for about 3 seconds. Again no matter what compiter is used this happens.
Moderator please don't swear.
geposted Thu 04 Jul 19 @ 4:53 am
HAVING SAME ISSUES WITH MY SYSTEM. KEEPS STUTTERING. PAUSING STOPPING AND THAT'S WITH OR WITHOUT EXTERNAL SOUND CARD. WISH THEY WOULD SEND ME A NEW VDJ 8 SYSTEM
geposted Thu 22 Aug 19 @ 4:03 pm
Please don’t shout. Have you run a latency checker as I mentioned earlier in this thread?
geposted Thu 22 Aug 19 @ 6:33 pm
I am having a serious problem the shuttering for 1/2a second..it happened 5 times today while doing a gig ..i need help ..have tried every latency settings. I did run latency mon..and telling me something about cpu throttling that i should disable...i need help
geposted Mon 06 Dec 21 @ 4:36 am
I am having a stuttering issue after about 25 minutes of playing...it only happens if i use my dj controller as the sound card but it doesn't happen when i use my laptop sound card ..i have tried everything..i used latencymon and it told me something about computer throttling and bios and also something about a driver that is Being used ...at the end of the day I just need a solution. Please thats all I am asking what should i do to stop this stuttering..it also happens on virtual dj 2020 I don't know what to do ...please help me i am desperate
geposted Thu 09 Dec 21 @ 5:35 am
I am assuming that due to fact that i am jamaican..i cannot get any customer service from the community chat room
geposted Sat 11 Dec 21 @ 9:54 am
I have used latencymon and got a reading but honestly don't understand what the program is asking me to do
geposted Sat 11 Dec 21 @ 9:57 am
I am having a stuttering issue..happened 5 times at a gig last Sunday..have not played since...dod the latencymon check got the results but cant understand what to do..need some assistance
geposted Sat 11 Dec 21 @ 10:09 am
If you have a Dell, Wfd1000.sys latency issues are often caused by the Dell Support Assist program.
Uninstalling that could help.
geposted Sat 11 Dec 21 @ 10:35 am
