Topic: Undo_load & karaoke
NicotuxHome userMember since 2014
During karaoke found it usefull to use "undo_load" to fast reverse to previous singer for some reason... mainly pressed twice the play button
while the song reloads and plays ok there are somme issues:
- the status does restore to karaoke playing, and karaoke skin will display the same way as playing a karaoke file in automix
- the track reloads in karaoke list but BEFORE the first karaoke moving down the karaoke playing index - it seems only a VDJ restart can reset it to 1
- unloading the track insert a blank 0 length unplayable track
- removing it and pressing play loads & plays browsed track
geposted Thu 06 Jun 19 @ 2:39 pm
