I have been using VDJ 8 for some time and have installed a +1 and -1 key change on buttons 1 and 5. I recently had an up date and now I find there is no way of knowing how many semitones up or down you are, there used to be a little figure next to "Key" that you could click on and it would tell you ie +4 or -4 but it won't do that now
geposted Thu 06 Jun 19 @ 3:31 pm
The key modifier is shown, on the key drop down.
geposted Thu 06 Jun 19 @ 4:02 pm
You can set the pad buttons to show the key change. In the "Name" field of the pad editor, enter this code:
`key & param_add -0.5 & param_multiply 12`
geposted Fri 07 Jun 19 @ 3:28 am
