When I connect my Numark mixtrack pro 3 controller to my laptop, No words come up on Karaoke screen, just black screen with virtual Dj in the corner, if i do not plug controller in then the words come up fine
geposted Fri 07 Jun 19 @ 8:14 am
make videoCrossfader does not blindly change when plugged
make sure videoVolumeLink is not activated with volume sliders down
sometimes default values are set when plugged in and do not always reflect the what the skin is showing
sliders may then need to resync with display most of the time you can see ghost sliders in this case
geposted Fri 07 Jun 19 @ 11:10 am
