Hi again! I take this mesage when i open the programm "database in C could not be opened" and i have lost all the information such as rating etc. Any help?
geposted Wed 12 Jun 19 @ 2:03 pm
geposted Wed 12 Jun 19 @ 4:38 pm[ selected best answer by locodog on Sat 15 Jan 22 @ 6:17 pm ]
Can happen in rare events when vdj doesn't close correctly. Restarting vdj normally sorts it, if not check taskmanager after closing vdj again and see if it has a process running.
Selected as best answer geposted Wed 12 Jun 19 @ 4:38 pm
Something happens with the file database. It saves it in some different places every time. Do you know what i have to do to fix it? Thank you!
geposted Thu 13 Jun 19 @ 7:05 am
I receive recurrently the message "database in C could not be opened" "database in D could not be opened" and I lost all the historical info as wellas my favourites !!!
geposted Sat 03 Oct 20 @ 10:09 am
This is also my problem since an update on 9/16/2020 - None of my aux drives , not even the original in C: can be accessed . All my processed tracks , downloaded album art , renames, added track info is not found . It's driving me nuts .
geposted Mon 05 Oct 20 @ 3:07 am
did u ever find out how to fix?
geposted Fri 13 Nov 20 @ 3:19 am
It's a common problem that is plaguing a lot of people:
https://www.virtualdj.com/forums/237339/VirtualDJ_Technical_Support/corrupted_database.html
geposted Fri 13 Nov 20 @ 1:08 pm
Simple fix is to Batch BPM and Covers.... Depending on your processor speed this can take a long while. But make sure you run in admin mode, it makes it faster
geposted Sun 25 Apr 21 @ 8:31 am
Happened to me, close VDJ then open Task Manager scroll down and you will find VDJ still there..click "End Task" It works!
geposted Sat 15 Jan 22 @ 6:09 pm
