If you look in History the singers for the karaoke song only show if you have karaoke and music filter set to on. If you have Karaoke only filter on the singer names disappear.
Just Karaoke
Karaoke & Music
Just Karaoke
Karaoke & Music
geposted Thu 20 Jun 19 @ 9:13 pm
Might be because you seem to have a music file in the list.
If that is actually a karaoke song, try to mark it as karaoke in the tag editor.
geposted Thu 20 Jun 19 @ 9:29 pm
I can confirm
a file played and registered in karaoke history not tagged as karaoke, whenever the type is, video or audio
when display karaoke only type is selected the singer field in browser disappear
in fact the singer field empty as far as the type of the file without singer and no karaoke tag is disable
the display format of "play time" also change from erroneous time to correct date/time
in karaoke mode, direct play a song/video by drag/drop to the deck. once it appears as played in karaoke history you have one
the play time issue is the same if you deselect display karaoke and leave display video only or display audio only depending of file type
geposted Thu 20 Jun 19 @ 10:07 pm
The files are all tagged as "karaoke" in the Tag Editor. All my karaoke files are zipped mp3+g, not sure that matters.
geposted Fri 21 Jun 19 @ 1:11 pm
BOB Airplanes in your screenshot does not appear to be marked as karaoke
geposted Fri 21 Jun 19 @ 1:31 pm
Not realy, your track "Airplanes.. by B.O.B" is not
geposted Fri 21 Jun 19 @ 1:32 pm
Airplanes was not karaoke. It is the regular music track played in between two karaoke singers. I never claimed ALL the songs in the list were karaoke.
geposted Fri 21 Jun 19 @ 1:36 pm
just answered at the same time.
but yes singer field disapear from karaoke files when a track without singer is not marked as karaoke and its type is not showing
and old playtimes are dummy when singer is showing
geposted Fri 21 Jun 19 @ 1:38 pm
geposted Fri 21 Jun 19 @ 4:55 pm
groovindj wrote :
All the "karaoke files" are tagged correctly as "karaoke". Next time I post I will check to make sure I am very specific; but, the issue remains.
geposted Fri 21 Jun 19 @ 6:48 pm
