os2l_info undocumented verb used in the menu of internal DMX pads opens a dialog
would be more usefull if it were localized
maybe it is tranlatable but its definition seems to be missing from language.xml
many other verbs tooltips reference were easy to guess but these one are somehow difficult to guess or not available
the same with "menu" buttons such as "SKIN LAYOUT" or "WAVEFORM_MENU"
or items of "vu meter menu" using skin_panel param="'vu_meter' on" : "Show vu meter" "Show output levels"
or items of "smartloop options"
and some verbs GET_EFFECT_SLIDER_NAME GET_EFFECT_SLIDER_TEXT GET_EFFECT_STRING_NAME
don't appear to have localizable tooltips
it look like these are finally the last ones to translate with the default set of skins
note: most of these are not set even in english language. They appear as action function name in tooltips which is not user friendly and users do not really care about
That's why i localized with some infos all of these in the french version I use
geposted Sat 22 Jun 19 @ 1:27 am
