when onScreenKeyboard is enable, not only when it display the ability to drag/drop is disable by the way
geposted Sat 22 Jun 19 @ 7:32 am
By default dragging is used for scrolling in this case. You can drag the cover art in grid view though, or use 2 fingers.
Alternatively you can use the option twoFingerScroll to swap this behavior.
geposted Sat 22 Jun 19 @ 8:55 am
Sure this feature makes sense when in touchscreen mode, but when not in touchscreen mode there is no possibility to drag from cover or from coverflow
display the cover art in text list is not really usefull in this case and does not allow to drag or would be difficult
maybe keeping the drag ability by default while not in touchscreen mode would be fine
thanks for the tip
using multiTouchTwofingerScroll effectively disable this behavior
strange setup however !!
browser : onScreenKeyboard 'on'
browser : multiTouchTwofingerScroll on
skins: touchScreenMode no
works fine
skins: touchScreenMode on
is fine either
and VDJ keyboard somehow localize : ascii for english french german and greek
many thanks
thanks for the tip
works fine
is fine either
many thanks
geposted Sun 23 Jun 19 @ 4:54 pm
Why would you need an on screen keyboard if you're not using a touchscreen?
geposted Sun 23 Jun 19 @ 5:02 pm
because of water... coffe... punch... wisky... battery fails ;)
I do (allegedly) have only one touchscreen
That's may be just bad organization though LOL
geposted Sun 23 Jun 19 @ 5:12 pm
Yeah, that's what backup equipment is for! :-)
geposted Sun 23 Jun 19 @ 5:53 pm
I better use backup equipment in case of real emergency such as audio/video/hdd/System failure and only when own system is in use ...
leak of keyboard is anoying but not an emergency at worth the wireless keyboard with touchpad from one videoprojector will do & most of the controllers have the ability to use the browser.
However for fastest operations in such cases i now set a custom tristate + reset button:
Keyboard=setting 'multiTouchTwoFingerScroll' & setting 'onScreenKeyboard' & holding ? setting 'onScreenKeyboard' auto & setting 'multiTouchTwofingerScroll' off : setting 'touchScreenMode' 'on' ? nothing : setting 'onScreenKeyboard' 'on' ? setting 'multiTouchTwoFingerScroll' on & search : setting 'multiTouchTwoFingerScroll' off
The first initial "setting 'multiTouchTwoFingerScroll'" is only for button state
The "search" raise the keyboard when it enable
disabling the keyboard while keyboard show keep it visible until real keyboard is used. badly if it were the VDJ keyboard it does not work out of search zone
holding "keyboard" buttin reset the settings to their default
Just wat I was asking for
geposted Mon 24 Jun 19 @ 2:41 am
