Topic: Gemini PMX 10
On the Gemini PMX-10 the asio driver does not work cannot get it to play out to the speakers .and i have Phase hook up and it Does not want to work at all.But when i put it on {Wasapl} the sound come out the speaker but phases still don't want to hook up virtual dj saying hook up a controller and i have the pmx -10 hook up .can someone help me with this matter please.
geposted Sat 22 Jun 19 @ 11:02 pm
Bring back the Gemini ASIO (install if you havent) and use it in Audio setup or else the Inputs required for the DVS(Phase) may not work.
Make sure you select the Mixer (Hardware) mode and follow instructions for DVS as per the manual http://www.virtualdj.com/manuals/hardware/gemini/pmx10/advanced.html
If you still have issues, try to follow the manual step-by-step and post here your screenshots.
If you manage to resolve proper audio routing from the Gemini, and you still have issues with the Phase, keep in mind that it needs LINE/CD Inputs. Doesnt work in PHONO. So Nr.31 as shown here need to be switched to LN http://www.virtualdj.com/manuals/hardware/gemini/pmx10/frontrear.html
You may also find some useful information about Phase here.. http://www.virtualdj.com/forums/228583/VirtualDJ_Technical_Support/Phase_don_t_work__solved_.html
geposted Sun 23 Jun 19 @ 1:55 am
