Topic: distance between browser lines ...
MANY THANKS for realize this feature. It's very helpful for my stressed eyes. Best regards.
geposted Tue 25 Jun 19 @ 7:55 pm
It does seem to have had an adverse effect on the display of text in skins though. I've noticed how text that used to fit fine now doesn't fit.
Before
AFTER
geposted Tue 25 Jun 19 @ 9:08 pm
Bump
Can we have a fix please?
geposted Mon 01 Jul 19 @ 4:26 pm
Which skin is that?
geposted Mon 01 Jul 19 @ 4:30 pm
It's a VDJ 7 default skin, but it's affecting VDJ 8 skins too. I just used that as an example because the problem is very obvious.
geposted Mon 01 Jul 19 @ 4:52 pm
Is this still an issue with latest Build 5046 ?
geposted Wed 03 Jul 19 @ 2:41 pm
I'm still on 5045 because 5046 apparently only fixed a Mac issue, and I'm on PC.
Oh hang on - why does 5046 EA only say "Fix some texts difficult to read on non-retina mac" yet 5046 standard (same release date) lists lots of things?
The pop up that appears when I start VDJ only lists the EA fix, so I didn't update.
[later] OK so now I have allowed VDJ to update to 5046 and the text issue in the skins remains. I'm not sure which 5046 just installed though. Why are there two?
[even later] I've now updated the 64 bit version directly from the link in the 64 bit thread - still the same. However, my 32 bit version (auto updated to 5046) is OK.
geposted Wed 03 Jul 19 @ 4:34 pm
geposted Thu 04 Jul 19 @ 5:55 pm
