hi , sorry if this has been asked before ... after a recent update my headphone levels are less than half of what they were before - so much so that its now impossible to mix even with the headphone level on full - i can hardly hear either track .... any ideas ?
thanks !
thanks !
geposted Wed 26 Jun 19 @ 2:37 pm
Take a look at Settings>Options>audio>headphonesGain
Mine is 0.5 as an example.
geposted Wed 26 Jun 19 @ 4:03 pm
cant find that setting - looked in options - settings - but nothing about headphone volume is there ?
geposted Wed 26 Jun 19 @ 6:44 pm
Make sure you are viewing "all settings" and not "most used" or "modified. Or, better, search for headphonesGain
geposted Wed 26 Jun 19 @ 6:47 pm
thanks all , mine is set at 0.5 also - did a complete re-install and its all working normal again ( i think ) !
geposted Wed 26 Jun 19 @ 8:37 pm
