<menu>Info... =[os2l_info]
Edit localhost =[set AAA 127 & set BBB 0 & set CCC 0 & set DDD 1 & set byte 1 & set byte2 3]
Edit 2.0.0.x =[set AAA 2 & set BBB 0 & set CCC 0 & set DDD 0 & set byte 0 & set byte2 3]
Edit 10.x.x.x =[set AAA 10 & set BBB 0 & set CCC 0 & set DDD 0 & set byte 0 & set byte2 3]
Edit 192.168.x.x =[set AAA 192 & set BBB 168 & set CCC 0 & set DDD 0 & set byte 0 & set byte2 3]
Set new IP =[get_text "`get_var 'AAA' & param_cast '000'`.`get_var 'BBB' & param_cast '000'`.`get_var 'CCC' & param_cast '000'`.`get_var 'DDD' & param_cast '000'`" & param_cast text &setting 'Os2lDirectIp' & set byte2 -1]
Remove IP =[setting 'Os2lDirectIp' '' & set AAA 0 & set BBB 0 & set CCC 0 & set DDD 0 & set byte 0 & set byte2 -1]
`setting 'Os2lDirectIp'` =[setting 'Os2lDirectIp' & param_cast float & set AAA & get_var AAA param_cast frac & param_cast frac & param_multiply 1000 & set BBB & set CCC 0 & set DDD 0 & set byte2 -1]</menu>
<param1 name="IP `var 'byte2' -1 ? setting 'Os2lDirectIp' & param_cast text : get_text 'Field : '``var 'byte2' 0 ? get_text 'AAA.___.___.___' : var 'byte2' 1 ? get_text '___.BBB.___.___' : var 'byte2' 2 ? get_text '___.___.CCC.___' : var 'byte2' 3 ? get_text '___.___.___.DDD'`">up ? repeat_stop 'rep' & var 'byte2' 0 ? set 'byte' 'AAA' : var 'byte2' 1 ? set 'byte' 'BBB' : var 'byte2' 2 ? set 'byte' 'CCC' : set 'byte' 'DDD' : repeat_start_instant 'rep' 250ms 0 & param_smaller 0 ? cycle 'byte2' -4 : cycle 'byte2' +4</param1>
<param2 name="Address: `get_var 'AAA' & param_cast '000' `.`get_var 'BBB' & param_cast '000' `.`get_var 'CCC' & param_cast '000' `.`get_var 'DDD' & param_cast '000' `">up ? repeat_stop 'rep' : repeat_start_instant 'rep' 250ms 0 & param_smaller 0 ? cycle 'byte' -256 & var 'byte2' 0 ? set 'AAA' 'byte' : var 'byte2' 1 ? set 'BBB' 'byte' : var 'byte2' 2 ? set 'CCC' 'byte' : set 'DDD' 'byte' : cycle 'byte' +256 & var 'byte2' 0 ? set 'AAA' 'byte' : var 'byte2' 1 ? set 'BBB' 'byte' : var 'byte2' 2 ? set 'CCC' 'byte' : set 'DDD' 'byte'</param2>
geposted Sat 29 Jun 19 @ 2:36 am
OK < and > - and other that disapear - can be specified in title as html entities
they must not be specified as html entities in post body
html entities are initially shown as they are in the body
if for some reason convert them to the character they represent is needed edit the comment and send it gain without any modification
this time the html entities are interpreted
simply take care bbcode like posts are removed
geposted Sat 29 Jun 19 @ 2:48 am
192.168.1.11.44189
geposted Fri 13 Sep 19 @ 2:01 pm
