Forum: Wishes and new features
Topic: Re: 8 Decks
I've been using 6 decks for a long time and find it a great way to actually make a track. Saying that though 6 tracks is just not enough sometimes.
It would be great if there was an 8 deck option. Using a DAW is great but sometimes it's good to be doing a mix and then actually turn it into a track using the snippets and samples of the tracks that you're playing.
Just a thought :)
geposted Sun 30 Jun 19 @ 9:50 am
FYI VirtualDJ can use up to 99 decks, and there are skins that have more than 6 decks. Check out the skin downloads...
You can also use the sampler to play stuff (loops, whole tracks).
geposted Sun 30 Jun 19 @ 10:00 am
Thanks GroovinDj...I didn't realise this, I'll check it out.
geposted Thu 12 Sep 19 @ 6:54 am
I've just downloaded the 8 deck skin which is great.
How do you use the sampler within this skin so I can manipulate a track and use it on a deck?
geposted Thu 12 Sep 19 @ 8:00 am
locodogPRO InfinityModeratorMember since 2013
drag and drop from list view
geposted Thu 12 Sep 19 @ 8:12 am
Once you've loaded tracks onto the decks, is there a way of saving the setup, so it will always open with those tracks?
geposted Thu 19 Sep 19 @ 9:40 am
NicotuxHome userMember since 2014
you may try using the following verbs
save_deck_set
load_deck_set
i.e. in combination with ONINIT & ONEXIT
geposted Thu 19 Sep 19 @ 2:30 pm
