Topic: Video: problem with text display
I'm having a minor issue with text in video being cropped a little:
Thoughts?
geposted Mon 01 Jul 19 @ 12:36 pm
You are not the only one, I have exactly the same problem.
geposted Mon 01 Jul 19 @ 1:38 pm
It's the update Atomix did to add browser padding. If you go back to a build before browser padding, you should find it's OK again.
It's affecting normal skins too.
geposted Mon 01 Jul 19 @ 4:22 pm
I changed the setting "experimentalScinEngine" from "auto" to "no" and the problem was gone. Then this setting to "yes" and now everithing fine. Back to "auto" and everything ok now. (v8.3 b5046)
geposted Tue 02 Jul 19 @ 2:40 am
No issue here with latest Build 5046. Anyone still has an issue ?
geposted Wed 03 Jul 19 @ 2:38 pm
Yes, the trick as described works in the 32 bit, but not in the 64 bit version (v8.3-64 b5046). PC W10
geposted Thu 04 Jul 19 @ 4:56 am
Can't reproduce with VDJ 32bit Build 5046, with experimentalSkinEngine to Yes or No.
There is an issue with the 64bit Build though (we see that), and will be fixed in a future update.
geposted Thu 04 Jul 19 @ 9:18 am
I am also unable to reproduce, but I am so happy that it works so far. Thank you for your great work.
geposted Thu 04 Jul 19 @ 9:24 am
This problem appears to be fixed in the latest 64-bit beta.
Good luck.
geposted Fri 12 Jul 19 @ 4:02 pm
Everything ok now.
v8.3 b5095 and v8.3-64 b5095. W10
Thanks a lot.
geposted Sat 13 Jul 19 @ 2:47 am
