Topic: xdj-rx and setup of virtual dj 8
infoPRO InfinityMember since 2019
I have just purchased virtual dj 8 infinity to setup my pioneer xdj-rx and finding that the software will not control my device. Could you advice the correct set-up of this to work with out any problems.
Many thanks
Mick
geposted Mon 01 Jul 19 @ 6:08 pm
You've got that backwards. The device controls the software. Did you read the setup guide?
geposted Mon 01 Jul 19 @ 6:12 pm
The problem was that it didnt control anything but I have now managed to get the unit setup and appears to be all working, just want to know how to switch the cross over fader off in the software, if possible.
geposted Mon 01 Jul 19 @ 8:39 pm
all sorted now
geposted Mon 01 Jul 19 @ 9:30 pm
hit another problem does anyone know how to turn on security prompt when you load a track on a playing one, basically turn stop it from auto load and stop the track that is playing.
geposted Mon 01 Jul 19 @ 10:00 pm
lincol2PRO InfinityMember since 2011
see options ..loadsecurity
geposted Tue 02 Jul 19 @ 1:03 am
RTFM
geposted Tue 02 Jul 19 @ 4:39 pm
