Topic: Beatlock reset function
I went through the advanced setting to see if there was a checkbox for the beatlock to be released (or a similar reset function) for when I load the next song on to the next deck. Is there a setting for that and I'm just not seeing it?
geposted Thu 04 Jul 19 @ 5:04 am
+1 would be a nice feature
Easily solved with a oninit repeat_start script that checks for load_pulse
I've a blog artical about it on my homepage.
Found your blog...attempted the script. I obviously didn't do it right.
As usual. You can do it with Virtual DJ, but it is complicated. No help from atomix itself.
Moderator please don't swear and I'm helping OP via PM's
btw the better option seems to me "pitchlock" and this reset when a new track is loaded
In latest version there's a key <ONSONGLOAD> on the keyboard mapper (and only the keyboard)
You can use that key to execute any actions you like when a new track gets loaded on a deck.
Eg: loop_select 4 & pad_page 'hotcues' & beatlock off
