Topic: Pioneer DDJ-RZX Screens
Hi folks,
Build 8.3 b5046 Mac
OS Mojave 10.14.5
RZX has latest firmware 1.10 and Mac has latest installed DDJ-RZX Audio Driver 2.0.1
VDJ has installed RZX Screens add-on and it is showing in "Documents - VirtualDJ - Skins" folder as a .zip file.
Controller works exactly as it should with no lagging or faults.
When DDJ-RZX is connected via USB, Open VirtualDJ,
First instance is 2 x deck screens on RZX go blank, centre screen stays on "USB CONNECTED" mode then VDJ crashes and reboots within a a few milliseconds.
upon reboot, 2 x deck screens go blank then show VDJ logo for approx 2 seconds before returning to "Rekordbox - Midi Control" logo.
Firewall is OFF
DDJ-RZX USBLAN is showing as active and connected.
I am not getting the DDJ-RZX screens plugin to work at all. I have tried uninstalling the plug-in, restarting mac, re-installing plug in, restarting mac to no avail.
Can anyone offer some advice?
geposted Thu 04 Jul 19 @ 5:31 am
Sorry, quickly to add, RZX functions correctly when using Rekordbox and all screens function as they should so can not be a network issue.
geposted Thu 04 Jul 19 @ 5:38 am
Further update:
I've rolled back to build 8.3 b5003 on Mac and all appears to be working as it should with screens etc.
Possibly a small bit of coding missed out on the latest build or plugin is not compatible with latest update?
geposted Thu 04 Jul 19 @ 6:11 am
Where do you find this build 5003? I have the same problem with my RZX
geposted Sun 07 Jul 19 @ 8:28 am
Support/wiki/download previous builds
geposted Sun 07 Jul 19 @ 9:40 am
Sorry ! Mac versione?
geposted Mon 16 Sep 19 @ 7:36 pm
Yes, the Mac version is there. Did you not look?
geposted Mon 16 Sep 19 @ 7:41 pm
eazydwayne2000 wrote :
Hi folks,
Build 8.3 b5046 Mac
OS Mojave 10.14.5
Firewall is OFF
I exactly have the same issue, perhaps related to the new firmware 1.10 upgrade.
geposted Wed 20 Nov 19 @ 3:46 pm
Please update to latest version. There was a bug on the MAC version at some point that made RZX crash, but it has since been fixed.
geposted Wed 20 Nov 19 @ 3:53 pm
Using Windows but latest build is not working
geposted Sun 02 Feb 20 @ 12:31 am
